97 Accord f22 non V has a bad miss @2500 rpm
Old Mar 5, 2012 | 11:59 PM
blly8325's Avatar
Default 97 Accord f22 non V has a bad miss @2500 rpm
Just got into a 97 Accord. Runs good @ idle but when revved to 2500 rpm there's a bad miss fire. Changed wires plugs,internals in dizzy. Bad dizzy, comp.? Any advice would be great, thanks to all in advance.
Old Mar 12, 2012 | 11:59 AM
bairdandrew77's Avatar
It could be a huge variety of things. Are there any cel codes on? What kind of spark plug wires are you using?
Old Mar 12, 2012 | 06:19 PM
czr's Avatar
czr
it can be as simple as not placing the spark plugs in the correct firing order.
Old Mar 23, 2012 | 10:16 AM
blly8325's Avatar
Sorry I kinda gave up on waiting on replies. I work nights that doesn't help either w/ responding. Anyway yes CEL light stays steady amber until I let off the throttle, then it will start to blink. Once I get back on the throttle it will stay steady amber. On a cold start you don't feel the miss right away. Approximately after a min or 2 you can feel it at the 2000 to 3000 rpm range. The wires are less than 6 months as well as the NGK's plugs.
Old Mar 23, 2012 | 06:10 PM
What kind of spark plug wires are you using? The owner of an import performance shop over here says to use only quality honda wires, NGK wires should also work fine. And double check if it's in the correct firing order. Also be sure the spark plugs are set at the correct gap for your particular motor.
RedKnight
Jan 22, 2013 01:15 PM
kraftwerk
Aug 22, 2011 11:04 AM
tjk
Sep 30, 2010 01:26 PM
BigShelby
Apr 7, 2009 05:26 PM
AbaZ
18
Jul 16, 2008 10:23 PM
