97 accord water pump
Old Oct 21, 2006 | 12:03 AM
golman
Default 97 accord water pump
Hi everyone !
Just joined today after picking up a 97 Accord EX . Never owned a Honda before , but after a lot research decided that the 97 accord was a great deal and even more important very reliable . I have 84000 kms (50000 mi) on it with (I suspect ) the original belt. I will get the belt changed next week (had a previous bad experience with a 91 VW Passat timing belt=2000$) . My question is: should I replace the water pump also ?
Please consider mileage , age and climate conditions.(southern Lake Erie area)
Also , should I focus on any other specific maintenance issues at this time ?
Previous owner had annual servicing done until 2004 by the dealer.
Thank you!
Old Oct 21, 2006 | 12:06 AM
YeuEmMaiMai's Avatar
Default RE: 97 accord water pump
change all wearable parts when you change the belt
water punp
timing belt
tensioner
drive belts
and if not installed install the blanace shaft seal retainer
Old Oct 21, 2006 | 12:21 AM
golman
Will do ! thank you!
Old Oct 21, 2006 | 04:21 AM
deserthonda's Avatar
if car has not had a service since 04 ,,i would do a major service
plugs,NGK ZFR5F-11 ,, Honda spark plug wires , cap + rotor if still the original, fuel+ air filter, oil and filter, valve adjustment.replace the upper spark plug tube seals, the 4 seals located underneath ( inside ) the valve cover , tranny fluid if AT use Honda ATF-Z1 , if manual tranny 10w-30 engine oil , tire rotation.
Old Oct 22, 2006 | 10:53 PM
golman
Thanks desert! will do!
ksar
Oct 17, 2008 09:27 AM
scottdrag
Apr 6, 2008 10:13 AM
J2Performance
Jan 25, 2008 01:03 PM
J2Performance
Jan 15, 2008 12:46 PM
joe592
May 25, 2006 03:35 AM
