98 accord LSD transmission question
Old Mar 14, 2012 | 02:48 PM
czr's Avatar
czr
Default 98 accord LSD transmission question
i have looked for a few weeks and havent came up with a straight answer for this, but wich LSD transmission from a lude will fit my 98 accord f23a1 as in straight bolt up?
Old Mar 14, 2012 | 06:09 PM
g22cd5's Avatar
Supper Moderator
all H series trans will bolt to all F series blocks and vice versa
the trans code you want is M2B4
Old Mar 14, 2012 | 06:51 PM
czr's Avatar
czr
next question would be, will it work with a OBDII and the stock wire harness? cause isnt that an OBDI tranny?
Old Mar 14, 2012 | 07:06 PM
g22cd5's Avatar
Supper Moderator
ok hold on are we talkin about 5speed or auto?
Old Mar 14, 2012 | 07:09 PM
g22cd5's Avatar
Supper Moderator
5speed dont matter what OBD it is. auto it DOES matter. you will need a obd2 auto tras. I have to look for the trans code I'm not sure what the code for the lsd auto trans. From what I remeber it it's a direct swap no wiring needed. But you will have to swap the TCU out for the lude trans. If your even talking about auto trans
Old Mar 15, 2012 | 11:01 AM
czr's Avatar
czr
my CG3 is a 5spd nice to know i can just bolt it up!.....thanks for the info man. and if im not mistaken the only difference in gear ratio is that the "H" is shorter and the "F" is longer for fuel economy.
illestwill
Apr 21, 2014 01:18 AM
maverick21383
Feb 26, 2013 09:54 AM
MessAround
Aug 13, 2011 09:45 AM
Boogie
Jun 12, 2011 01:07 PM
s20700134
Dec 27, 2006 07:52 AM
