99 Accord overheating
Old May 1, 2007 | 04:55 AM
jombolo's Avatar
Default 99 Accord overheating
For whatever reason my radiator fan is not coming on by itself. I tested it, works when i turn the AC on, both fans come on. I replaced the radiator fan switch thinking that was the problem. But didn't fix it. Thing heats up super quick since the fan wont come on. I checked coolant, plenty of it in the system. thermostat is fairly new. Anyone know what else could be keeping the fan from coming on?
Old May 1, 2007 | 07:08 PM
jombolo's Avatar
Default RE: 99 Accord overheating
I've replaced the radiator fan switch, the fan works fine (it may have worked all along, i dont know) and i also replaced the thermostat. But the car is still over heating. Might it be the sending unit?
Old May 2, 2007 | 11:22 AM
Could be the gauge sending unit or a short in that wire to the sender.
Explain the situation where it overheats; explain the behavior of the gauge. Gauge moves fast or slow? Gauge goes all the way up into red? Happens while driving? Happens when stopped & idling? etc...
The gauge sender is in the end of the head, it has a single wire. Unplug it. The gauge should drop to cold. If you can wiggle the wire & cause the gauge to rise at all, then you need to fix that.
Old May 2, 2007 | 06:31 PM
jombolo's Avatar
Yeah, i tested that with an ohm meeter. It appears to be working fine. I just decided to take it in...got to frustrated with this damn car. Hah, thanks for the suggestion
Old May 2, 2007 | 06:58 PM
sir_nasty's Avatar
Let us know what they find.... sounds like a temp sensor to me...
Old May 2, 2007 | 08:42 PM
Was it the coolant temperature sensor that was faulty?
Joshporsche
Jun 14, 2006 10:07 PM
Rizzie
May 28, 2006 12:04 AM
copa708
Apr 24, 2006 08:36 PM
mennerja
Jan 6, 2006 10:03 PM
erikhaha
Nov 20, 2005 02:48 AM
