ABS 1-2 fault code
Old Apr 28, 2008 | 03:10 PM
AccordNSTL
Default ABS 1-2 fault code
Please help. I'm new to the forum and recently purchased a 1993 Honda Accord SE with 164,xxx miles on it. Itruns great with the exception of the ABS light just came on. I have read past posts on how to check the faultcodes and believe the code is 1-2.Can anyone help? Thanks.
Old Apr 28, 2008 | 03:43 PM
sir_nasty's Avatar
Default RE: ABS 1-2 fault code
If you're reading the code right I believe that's a faulty abs regulator.... when you first turn the key on can you hear the system try to pressurize? is your fluid full? Are you leaking any fluid?
Old Apr 29, 2008 | 01:14 PM
AccordNSTL
sir_nasty, thanks for the reply. I don't here the sytsem try to pressurize, both brake reservoirs are full and there are no leaks. The ABS system started to engage erratically when it began raining. The next day the ABS light was on and the system no longer functioned. After shorting the test plug under the glove box with a paper clip and getting the 1-2 fault code, I also tested the bus fuses in the ABS fuse box under the hood with a test light. All the fuses tested good with the exception of the 7.5 amp fuselabled "ABS unit".I know the fuse itself is good but it seemsit is not getting power to it. With the info provided, where do I go from here? Thanks.
Old Apr 29, 2008 | 01:24 PM
According to my list 1-2 is for a bad ABS pump motor. If you can rule outbroken wiring in the harness leading to the ABS modulator, I guess you replace the pump. Or get awhole ABS modulator assembly at a junkyard.
Old Apr 29, 2008 | 03:53 PM
AccordNSTL
Thanks JimBlake. I'll be more than glad to check the wiring harness leading to the ABS modulator if I only knew where the ABS modulator and/or the pump motor is located. Can you guide me? Thanks.
Old Apr 29, 2008 | 04:19 PM
deserthonda's Avatar
chk all the fuses in the underhood ABS box ....abs 1 , 2 , 3 , abs unit, abs motor 50 amp also chk the # 8 fuse underdash fuse box 7.5 amps...could be a bad relay as well
Old Apr 30, 2008 | 02:52 PM
AccordNSTL
Everyone, thanks for allthe info. I rechecked the 7.5 amp "ABS unit" fuse in the ABS fuse box under the hood andfound it blown. Replaced fuse and the ABS light cleared. I'll drive it and seewhat happens. I'll post again with results.
Old Apr 30, 2008 | 03:55 PM
Excellent. I love it when the fix is really easy...
printer33
Dec 1, 2011 05:42 PM
2fargone
Jun 8, 2008 10:18 PM
billvaughn
Jun 1, 2008 07:57 PM
Koko
Feb 15, 2008 08:57 PM
appleman
Sep 27, 2007 11:44 AM
