ac control not sending signal to start ac compressor or fan
Old Aug 15, 2020 | 06:21 PM
Jeromie King's Avatar
Default ac control not sending signal to start ac compressor or fan
i have a 2007 accord exl with nav! and the compressor and fan will not come on, but i can hard wire both and they both come on! what can i do or replace ?
Old Aug 16, 2020 | 07:40 AM
Seanjordan20's Avatar
Did you check the relay or fuse
Old Aug 17, 2020 | 05:10 PM
What about the pressure-switch for the refrigerant? Either a failed switch or a true problem with refrigerant amount?
Old Aug 17, 2020 | 06:20 PM
A lot of info is missing to pin point the issue. With that I like to work from the box down. You are correct. Could be a switch or refrigerant level.
OP did it just stop one day or gradually got bad as in not cooling efficiently before it stopped.
gmancamp
Jun 11, 2015 08:00 PM
wade3673
Jul 2, 2011 06:38 PM
kendo
Oct 23, 2008 03:13 PM
dragonewbi
Jul 10, 2007 03:16 PM
flotown
Jul 10, 2007 12:54 PM
