accord wont hold idle
Old Dec 12, 2007 | 10:44 AM
doanutboi's Avatar
Default accord wont hold idle
my accord (h22a4 swap) was recently throwing out the code p0335 which was a ckp sensor malfunction. so i picked up a brand new ckp sensor from honda. before the install of the new sensor my car still started and idled fine only problem was that it could not rev past 3rpm. now after i installed the sensor. my car wont hold idle at all. any idea whats wrong? the codes its throwing outare p1362, and p0336. thanks in advance for the advice.
Old Dec 13, 2007 | 08:08 AM
noboundaries6289's Avatar
Default RE: accord wont hold idle
do you have stock or aftermarket intake? If aftermarket, there is a vacuum line you might have disconnected from the sensor (I did before i rerouted it) anyways, my car idled rough without it. When i put it back on with some custom routing, it worked fine. I think it was the IAC vacuum line. Maybe. please correct me if im wrong anybody.
brian74d
Dec 11, 2013 07:46 AM
emorr
Aug 26, 2013 06:03 PM
laboofacurry
Dec 13, 2011 06:02 AM
mark28269
Sep 10, 2008 02:27 PM
