Adjusting idle
Old May 29, 2013 | 10:09 PM
Roch.nicholas's Avatar
Default Adjusting idle
Do i actually need to use a tachometer and disconnect EVAP solenoid before adjusting the idle screw in park? I own a 1998 honda accord 4 cyl ex my car is idling a lil higher then 750rpm after installing new spark plugs and spark plug wires.
Old May 29, 2013 | 10:33 PM
94ex915's Avatar
Almost A Senior Member
750 doesn't sound to abnormal. Then again I don't know to much about your year. Lets see if anyone else could be a better help.
Old May 29, 2013 | 10:40 PM
650-750rpm is normal its reving around 800ish.
Old May 30, 2013 | 06:34 PM
There is a write up by Jim in the Common DIY threads sticky in the top of the general tech section about checking/adjusting the idle.
Old May 30, 2013 | 07:22 PM
Kk thank you
modeman
Apr 11, 2019 08:28 PM
Kerby
Jun 13, 2011 09:22 PM
kbrown@insystcom.com
Feb 27, 2007 05:07 PM
dave118811
Dec 17, 2006 06:08 AM
shaleck
Oct 20, 2006 08:25 PM
