alternative to high compression, forged, and stock pistons?
Old Nov 6, 2007 | 06:28 PM
thunder_x's Avatar
Default alternative to high compression, forged, and stock pistons?
is there any other type of piston that is better than the above listed?
Old Nov 6, 2007 | 07:00 PM
sir_nasty's Avatar
Default RE: alternative to high compression, forged, and stock pistons?
Depending on the application they make different shapes on top of the piston, domed is the one I've most commonly heard of... as far as better I think it all depends on application
Old Nov 6, 2007 | 11:05 PM
thunder_x's Avatar
how about a naturally aspirated motor
Old Nov 7, 2007 | 07:06 AM
BlkCurrantKord's Avatar
For a naturally aspirated motor you'd want a domed piston. For a motor seeing boost you'd want a dished piston. Most motors come with cast pistons from the factory. Almost all aftermarket pistons are forged.
Old Nov 7, 2007 | 08:39 AM
falkore24's Avatar
domed vs. dished is mostly to adjust the compression ratio. Domed = higher compression = good for NA. Dished = low CR = good for boost.
nvecsey
May 30, 2009 08:48 AM
nafango2
Nov 16, 2007 08:52 PM
leadfoot
Jul 27, 2007 09:58 PM
9JordonFlex9
Apr 12, 2006 04:57 PM
Sep 27, 2005 09:46 PM
