Anti Freeze Question
Old Oct 16, 2010 | 07:02 PM
Special_K's Avatar
Default Anti Freeze Question
Winter is comming here, I just check and changed my fluids and came accross my anti freeze...it is still good but the level is at the maxium line...owners manual said it should be in between max/min. Honda type2 anti freeze is pre mix 50/50 so overtime water will vaporate? should I keep it at the maxium or bring it in between?
Old Oct 17, 2010 | 09:23 AM
g22cd5's Avatar
Supper Moderator
You will be fine the way it is. BUT if you really want to you can bring it down some if it makes you feel better
Old Oct 17, 2010 | 12:41 PM
If you fill it to the max when it's cold, then it might overflow when hot. Make it somewhere in the lower 1/3rd of the range, then it will probably be near max when it's hot. Or just watch where the level goes when it's hot.
aloha_bruddah
Aug 24, 2013 01:15 AM
jaemin2
May 19, 2009 08:00 AM
HondaOldTimer
Dec 6, 2008 07:40 PM
Accord91Pearl
Aug 14, 2008 06:56 PM
noboundaries6289
Feb 14, 2007 01:21 AM
