auto engine in a manual accord
Old Aug 22, 2008 | 02:52 PM
amahabir
Default auto engine in a manual accord
hello everybody,
i have a 1992 accord ex, 5 speed with about 220,000 miles.
it is leaking and have a lot of miles and i would like to get the engine rebuilt or whatever is cheaper (like buying aused engine) for me at the moment.
Does anyone know if I can put an automatic engine in my manual honda if i do decide to buy a used engine. My reason for asking this is the autos prob have less wear on it than the manuals.
Tried searching for this but could not find anything, all i have found is conversion from an auto to a manual.
Old Aug 22, 2008 | 03:24 PM
cjdm98's Avatar
Default RE: auto engine in a manual accord
Uhm... There is'nt really such a thing called "automatic" engine.If the engine is the same size as your previous one then it should bolt right up, but then again, not every car is the same,and some adjustment i.e. flywheels,bolts etc...
Old Aug 22, 2008 | 03:44 PM
Crankshaft is the same, but the bolts for the flywheel are different than the bolts for the auto flexplate.
The rear engine mount may be different too, but Im not sure?
Its not a dum question, either. Some cars (probably not Accords) use a different camshaft, or different ECU map when they come from an automatic car.I dont think Honda does that, but I do think theres a jumper in the ECU that you have to either remove or install...
ps... Just noticed its your first post. WELCOME!
Old Aug 22, 2008 | 10:45 PM
if its the same motor it should work no problem, i put a h22 that was attached to a automatic tranny in my accord thats a manual
cliff
Apr 15, 2013 02:27 PM
Max Utility
May 19, 2011 12:32 AM
saanich
Sep 29, 2009 02:41 AM
Miran
May 20, 2009 07:57 AM
