beginning of h22a build.
Old Apr 12, 2010 | 10:10 PM
corlude's Avatar
Default beginning of h22a build.
darton mid sleeve eagle rods an mahle pistons.the head is good but the block needs work.i found the sleeve for for 635 and the piston/rod set for 830.the only problem is its from ebay stores...what to do?????
Old Apr 12, 2010 | 10:12 PM
corlude's Avatar
also i have 2000 to work with so far am i doin alright or will i need more cash
Old Apr 12, 2010 | 10:15 PM
corlude's Avatar
i really didnt want to bore the block.from what im reading the proper way to put new pistons in an H series is to sleeve it because of the material the block is made of.true or false?
Old Apr 12, 2010 | 10:42 PM
clutch811's Avatar
sleeving is correct, that frm material is a PITA. what are your plans with the build? N/A? turbo? do you know what you are getting into? 2000 is not gonna cut it for a good N/A build.
Old Apr 12, 2010 | 10:44 PM
corlude's Avatar
yea no turbo all motor high compression pistons on a stock bore i called the shop i take my car to today an they will sleeve my block for a few hundred.im hoping after sleeve cost an labor i would be just under 1000$.then there is the cost of the pistons/rods an hopefully the crank shaft dsnt need to be spun or replaced
Old Apr 12, 2010 | 11:00 PM
corlude's Avatar
as far as bearing/other internal parts in the block go what should i need
Old Apr 22, 2010 | 11:57 AM
g22cd5's Avatar
Supper Moderator
You don't have to sleeve the block if you run the Mahle Gold Series pistons you can get high c/r pistons for your n/a build. They are designed to run with stock sleeves. They run about $500 for the set check ebay.
NINETY5LX
Jul 27, 2025 09:33 AM
hitek85
Feb 12, 2008 10:32 AM
nitehawk
Dec 16, 2007 08:51 PM
importnewbie
Aug 16, 2007 05:11 PM
98Accord220HP
Jun 25, 2006 03:39 PM
