is it better to have more torque or more horsepower?
Old Jul 28, 2006 | 04:02 AM
  #31
YeuEmMaiMai's Avatar
Default RE: is it better to have more torque or more horsepower?
care to vack that up with some facts instead of just rambling on? I have provided my facts......
Old Jul 28, 2006 | 09:35 AM
  #32
Chiovnidca's Avatar
ORIGINAL: YeuEmMaiMai
A five speed will let you rev the engine up to a good power produceing rpm before launching. That's a pretty good fact.
Old Jul 28, 2006 | 11:03 AM
  #33
you can do the same exact thing with an auto. It's called stall speed and you can have it set to anything you want at the time you set up and install your torque converter. It is not uncommon for racing ones to be set to 5K or higher.
Another fact. Automatics can outshift a good or lower stick driver anyday. The automatic is far more consisitant and that is why they are making a strong comeback in drag racing....
Old Jul 28, 2006 | 12:10 PM
  #34
marbro's Avatar
Like i said, the technology behind the auto's have improved greatly, if you put an early 90's auto against an 2000 auto the 2000 will win because the technology behind the mechanical design and electronics is much better, I have a 98 and it shifts through gears as fast a person whos speed shifting. Then you have a high stall torque converter which it get you more jump off the line, even though the car becomes worthless for daily driving.
Legion, heres my question...... have you ever driven a 350z auto? I can tell you right now you will never be able to shift gears as quickly and smoothly as that auto does, and you definetly wont have the exact same shift consistency.
Old Jul 28, 2006 | 01:01 PM
  #35
legionofone's Avatar
well gimme a nismo setup with a short shifter and a act stage 3 racing clutch and ur on... but yeh automatics just mean perfect shifts... but they also dont leave any room for kicking the clutch... double clutching... (thats when u hold ur foot to the floor durring a shift it lets ur engine rev all the way and then u RE launch almost giving u a considerable speed boost)... and u definately loose power... o and control... (unless u have a ghey autostick then i guess u dont loose as much control) but the consistancy thing is why they are being used in drag racing... top fuel dragsters still run good old manuals... 2 speed manuals at that... u should see the fused clutches they have to pull out of the trannys after every run... its sick... u have to the smell of every fluid or sealant burning to work with those engines thats why im studying to build Rails Chassis fab and high performance baby
Old Jul 28, 2006 | 04:08 PM
  #36
Chiovnidca's Avatar
Dont see many high stall converters on hondas where i'm at. I'd hate to see what a 7000+ stall converter would be like on the street. That's where my civics like to launch.
Old Jul 28, 2006 | 07:48 PM
  #37
3200 is a average high stall torque converter
Old Jul 28, 2006 | 10:42 PM
  #38
mbo1985's Avatar
I need stronger axles to drop from that high. I already snapped an axle dropping it at 5k. I think I'd need a different motor to drop it from that high actually...
At 7000 RPMS that's got to be one serious launch!
Old Jul 29, 2006 | 01:02 AM
  #39
how the heck do u hook at 7k? i would think u would just sit there and slip
Old Jul 29, 2006 | 07:31 AM
  #40
02BlueAccord's Avatar
i would rather have more tq then hp. cuz in a race u dont race past like 100 on the street. if u have alot of tq u can smoke the other guy off the line and maybe get far enough were they wont be able to catch u
