bleeder valve
Old May 15, 2007 | 02:03 PM
1996AccordLX's Avatar
Default bleeder valve
I just replaced the radiator on my 1996 Accord LX and i had the hardest tiem locating the bleeder valve when i went to fill it back up. The bleeder valve is on the thermostat housing, BEHIND the motor right? Because on my mom's 1998 Oddysey, it's in front of the motor, so i was looking all over for it. I just want to make sure that it is on the thermostat housing behind the motor.
Old May 15, 2007 | 02:30 PM
sir_nasty's Avatar
Default RE: bleeder valve
I thought that it was on the front or side of the motor but I could be wrong...... just trace the upper radiator hose back to the engine and the bleeder valve is right there, like you said on the thermostat housing.... It's been a while since I paid attention but it sounds like you've got the right one.
Old May 15, 2007 | 11:37 PM
Most Hondas put the thermostat at the LOWER hose. And back there is where the bleeder shoud be. But some years didn't have one at all.
Some (B-series) engines have the bleeder located in the head alonside the uppwer radiator hose. Just depends where the air bubbles like to hang out when this happens.
Old May 16, 2007 | 12:55 AM
YeuEmMaiMai's Avatar
followthe upper hose and where it goes into the block (highest point of the cooling system) there should be a small nipple that you open to let the air out
Old May 16, 2007 | 08:02 AM
Bleed nipple is #12 here, that's in the thermostat housing. Might be easierif you remove the big intake duct. That's a4-cylinder engine since you didn't say...
Old May 16, 2007 | 09:18 AM
ok thansk guys, i found it on the lower hose back behind the engine block
harpcat
Mar 25, 2015 01:45 PM
MessAround
Oct 2, 2014 04:48 PM
jfidelh
Feb 26, 2013 10:03 AM
pinky0519
Jan 12, 2010 07:01 AM
Rainy
Sep 29, 2009 05:26 PM
