ATF Change via power bleeder/vacuum pump
Old Sep 28, 2009 | 12:16 AM
Rainy
Default ATF Change via power bleeder/vacuum pump
Has anyone been successful in using a power bleeder to change the atf via the dipstick tube vs. using the drain plug?
97 Accord LX 2.2L non-vtec.
Thanks.
Old Sep 29, 2009 | 12:46 PM
Rainy
Any help please?
Old Sep 29, 2009 | 01:40 PM
mcnoople's Avatar
Other than dealing with a stripped trans plug threads I don't see why you would use a vacuum pump. If the threads are intact and there are no wierd issues with the trans it would be easier to just pull the trans drain.
Old Sep 29, 2009 | 05:26 PM
deserthonda's Avatar
for as easy it is to remove the drain plug,,, .i would do it no other way
harpcat
Mar 25, 2015 01:45 PM
MessAround
Oct 2, 2014 04:48 PM
moey
May 22, 2011 10:43 AM
pinky0519
Jan 12, 2010 07:01 AM
1996AccordLX
May 16, 2007 09:18 AM
