Block adjustment to add psi
Old May 13, 2007 | 04:13 PM
KevinAccord's Avatar
Default Block adjustment to add psi
I'm installing a turbo system very soon. but i've been told that my stock engine only reaches a maximum of 12psi. even if i do some internal changes my block still won't hold more than 12psi... Is that true? is there anything i can do, like get a stronger block? how can i do that?
Old May 14, 2007 | 07:45 PM
marbro's Avatar
Default RE: Block adjustment to add psi
new rods, new piston, new rings, and a good head gasket, theres other things you will want to do, but those 3 are the big ones that go out on the engine rings goout firstif they are old, the rods go out at high boost
Old May 15, 2007 | 11:20 PM
ok, thanxs! any more suggestions will be apreciated.
How much psi will i be able to put into my engine if i do these changes?
Old May 16, 2007 | 02:27 PM
marbro's Avatar
That i dont really have an aswer for, if you replace the pistons rods and rings I would assume 15 to 20 but im sure thats theres little odds and ends that need to be changed as well. Ask chiovnidca he will be able to give you an idea based on his civic mods
Old May 16, 2007 | 02:58 PM
sir_nasty's Avatar
In my opinion if you're going to do internal work like that I'd have the valves, springs and retainers done as well and possibly consider a different cam..... once the engine is torn apart machine work and parts gets pretty inexpensive... if you have a f22 then f22parts.com might be a good place to start (94-97 accord)
blackadept
15
Jan 21, 2009 06:19 PM
yiannix
Nov 2, 2008 11:09 PM
rob3201
Mar 15, 2008 12:11 AM
rob3201
Dec 26, 2007 11:34 AM
2002haccord
35
Sep 8, 2007 02:32 PM
