Brakes
Old Feb 19, 2007 | 06:31 PM
sssexy70's Avatar
Default Brakes
How do you know when your brakes need bleeding? My pads and rotors seem fine but when i brake there is a lot of dead space and no pressure until i push them low. And if I hit them hard they push back. I don't have ABS.
Old Feb 19, 2007 | 07:49 PM
HondaRacer4Vtec's Avatar
Default RE: Brakes
Yeah sounds like they need some bleeding.
Old Feb 19, 2007 | 08:20 PM
poser_pilot6
Default RE: Brakes
Actually might be more than just bleeding. Could be the master cylinder going bad, I think that was one of the symptoms.
Old Feb 19, 2007 | 10:17 PM
sssexy70's Avatar
Default RE: Brakes
I don't think its the master cylinder because it doesn't feel like the power brakes are failing, there is just not a lot of pressure... but if it is one of the symptoms I'll get it checked out... do you know the other symptoms?
Old Feb 19, 2007 | 10:33 PM
poser_pilot6
Default RE: Brakes
Check this thread... it might help.
https://www.hondaaccordforum.com/m_25361/tm.htm
Old Feb 19, 2007 | 11:08 PM
sssexy70's Avatar
Default RE: Brakes
Thanks for that link, but the difference is my brakes don't feel weak... I feel like I still trust them in a bad situation... and i don't have to push lower to stop the car, its just very airy (if thats a word)
Old Feb 20, 2007 | 03:11 AM
Default RE: Brakes
The thread that Poser linked described a different problem. The difference can be a little subtle...
Air in the lines:
The brake pedal is initially soft & sinks low, but the brakes work. Usually the pedal comes up higher if you pump the brakes. Bleeding the brakes thoroughly should take care of this.
Bad master cylinder:
The brake pedal is firm when you first press it. But if you hold it with moderate or low pressure (like at a red light) it sinks slowly & smoothly to the floor. Usually the brakes work OK if you have to press them hard. Bleeding the fluid sometimes helps but it's only temporary.
alphaney
Feb 12, 2022 10:14 AM
phantomgrey92
Dec 22, 2015 10:24 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
