a/c eliminator kit
ORIGINAL: legionofone
pully and belt that mounts in the holes ur AC comp did
if i ran a shorter belt it would scrap pretty deep into the timing belt cover and i'll go through a couple of belts before it you run clean through. i could take it off the coverand cut it but i'd rather get the eliminator kit and just drop it in. its not that i dont want the a/c because i live in south fla but its bad and i'd prefer to ditch it rather then fix it.
ORIGINAL: pr3z
just by installing a shorter belt should not change the alignment of the belt .. like Chio says , there is something wrong that allows the belt to scrape the cover,, but ,, if that's the case , then even the longet belt should scrape on the cover
And do not cut the cover,, you do not want any debris and such to get inside the timing belt cover
