Can I use H22 rods with f22 pistons in an f-series build?
Old Oct 14, 2010 | 12:43 AM
HondaAccordEX94's Avatar
Almost A Senior Member
Default Can I use H22 rods with f22 pistons in an f-series build?
Bisi doesn't make steel rods for the f-series, only the h, k, d, and b. They have the GPR Aluminum rods for the f-series, though, but I was scared off when I read "For drag race and heavy street duty (40,000 mile lifespan) in warm climates only." I don't plan on doing a lot of racing, if any.
Old Oct 14, 2010 | 02:59 AM
g22cd5's Avatar
Supper Moderator
yes you can use the h22 rod they are slightly shorter tho...but you need to calculate in the rod being shorter when you do your math about your compression ratio. It will lower c/r than using a F series rod
Now h23 rods are the same as f22 rods BTW
Read my sticky about f/h engine specs that info is gold...
g22cd5
Jul 30, 2009 07:15 PM
nvecsey
May 30, 2009 08:48 AM
AbaZ
18
Jul 16, 2008 10:23 PM
nafango2
Nov 16, 2007 08:52 PM
importnewbie
Aug 16, 2007 05:11 PM
