check eng light 99 accord
Old Jun 5, 2011 | 08:35 PM
ghost rider's Avatar
Default check eng light 99 accord
New to forum. For a while now the check eng light has been on and I get a P 1457 code. I was told I need to take it somewhere and do the smoke test. They said I need a new egr valve. They told me it sometimes can be cleaned and then it will work and if it comes back on I will need to replace it. It came back on and I did some research and ended up replacing the egr valve and it was unsuccessful.
I looked more and found out that the egr valve would have had a p 1491 code. So I think they were set me up for a big repair job.
I looked under the car to locate the evap control canister and vent shut valve and I discovered a component mounted next to the evap control canister and that has a big crack in the plastic shell. I pointed to it in the attached picture. If any one knows what the part I’m looking at and if it makes since that it being cracked would cause a p 1457 code
hogdogs
Mar 19, 2012 11:56 AM
partsman1
Apr 17, 2009 08:46 AM
CRVtoAccord
Jul 3, 2007 01:09 PM
62maxx
Oct 26, 2006 01:04 PM
accordn2me
Dec 6, 2005 01:30 PM
