Clutch Fail
Ok so im going to get my clutch checked out. i recently kinda fried it getting out of a ditch but it was driving fine. Now as of last night i have not clutch pressure in the pedal and i had to muscle out each gear. What do you think is wrong?!?
RE: Clutch Fail
You said you fried it, what do you think is wrong? Did it smell? More than likely you burned it up.
RE: Clutch Fail
yeah it smelled for a day but drove fine
RE: Clutch Fail
Sounds like you've lost clutch fluid in the hydraulics. Probably a seperate issue to your clutch "frying" episode.
RE: Clutch Fail
so best check the fluid level?
RE: Clutch Fail
What do you reckon?!
RE: Clutch Fail
Check the fluid level. if low on fluid, add more and check for leaks. Pray you don't need a new clutch unless you want to spend a lot of money having it replaced.
RE: Clutch Fail
It needed replacing.....[:@]
RE: Clutch Fail
ORIGINAL: chopperkid44 It needed replacing.....[:@] |
RE: Clutch Fail
yeah. so turns out the steering wheels was off alignment, the oil sensor was leaking, and the master cylinder for the clutch needed to be replaced $800. not too terribly bad
