Clutch Fail
Old Dec 30, 2007 | 09:52 AM
chopperkid44's Avatar
Default Clutch Fail
Ok so im going to get my clutch checked out. i recently kinda fried it getting out of a ditch but it was driving fine. Now as of last night i have not clutch pressure in the pedal and i had to muscle out each gear. What do you think is wrong?!?
Old Dec 30, 2007 | 12:17 PM
BlkCurrantKord's Avatar
Default RE: Clutch Fail
You said you fried it, what do you think is wrong? Did it smell? More than likely you burned it up.
Old Dec 30, 2007 | 09:06 PM
yeah it smelled for a day but drove fine
Old Dec 30, 2007 | 09:16 PM
JohnL's Avatar
Sounds like you've lost clutch fluid in the hydraulics. Probably a seperate issue to your clutch "frying" episode.
Old Dec 30, 2007 | 10:03 PM
so best check the fluid level?
Old Dec 31, 2007 | 01:48 AM
JohnL's Avatar
What do you reckon?!
Old Dec 31, 2007 | 11:07 AM
00AccordLX5spd's Avatar
Registered User
Check the fluid level. if low on fluid, add more and check for leaks. Pray you don't need a new clutch unless you want to spend a lot of money having it replaced.
Old Jan 2, 2008 | 04:59 PM
It needed replacing.....[:@]
Old Jan 2, 2008 | 06:34 PM
JohnL's Avatar
ORIGINAL: chopperkid44
Why the angry face? You should be blissfully happy; 'it's ONLY the fluid level... thank you God!!!'.
Old Jan 3, 2008 | 03:48 PM
yeah. so turns out the steering wheels was off alignment, the oil sensor was leaking, and the master cylinder for the clutch needed to be replaced $800. not too terribly bad
