compression ratio
Old Aug 11, 2007 | 07:02 PM
phibbs87's Avatar
Default compression ratio
hey im kinda new at engines but im about to get the f20b and i wanted to know how would i decompress it so that i could turbo it?
Old Aug 12, 2007 | 12:35 AM
Velocifero's Avatar
Default RE: compression ratio
ORIGINAL: phibbs87
thats probably the worst engine to turbo. turbo something else, something cheaper with already low compression. like the f23, h23, or f22 series motors. they also all have cast iron sleeves, which is what you need for high boost.
Old Aug 12, 2007 | 10:05 AM
phibbs87's Avatar
thanks for that but i wanna be different so if you could know the answer to the original question id appreciate it. i aint going to be running really much boost probably just like 6-8 psi max
Old Aug 12, 2007 | 03:45 PM
Velocifero's Avatar
alright fine. the f20b already has iron sleeves so youre good there. i dont know of any kits off the top of my head but some low compression pistons and maybe a thicker headgasket would do the trick.
Old Aug 12, 2007 | 03:48 PM
BlkCurrantKord's Avatar
Find some F22 85mm borepistons. If you're not gonna be running much boost then there's really no point in replacing the pistons or turbocharging the motor in the first place.
Old Aug 12, 2007 | 04:08 PM
phibbs87's Avatar
well say that i get the f22 pistons how much boost do you think i could run on it? or should i just say **** it and go NA?
Old Aug 12, 2007 | 08:17 PM
F20B was meant for racing N/A...it should stay that way.
mspearin
Sep 28, 2024 04:07 PM
ashkumar76
Oct 29, 2013 05:29 PM
phantomgrey92
May 19, 2013 09:01 PM
2.2ex965spd
Apr 20, 2007 04:14 AM
Csparke
Dec 1, 2004 12:13 AM
