DTC and TCS codes meaning?
Old Feb 5, 2012 | 04:31 PM
tshunnar's Avatar
Question DTC and TCS codes meaning?
Hi Guys,
The check engine light on my dashboard has been on for some weeks now. it used to go on and off every now and then but recently for the past week or so it came on and went off. That’s been said, the TCS light comes on at some times when it should not. I managed to read the codes for both lights.
For the Check Engine Light, it gives me two codes, 12 and 20. The TCS light gives three long blinks and 1 short which means code 31 assuming it is the same method for reading the CEL. Does this combination indicates a known issue. Any ideas??
I found that code 12 for the CEL means a problem with EGR Valve and code 20 has to do with the Electrical Load Detector Circuit. No Idea what code 30 for the TCS indicates. Any help would be appreciated.
Old Feb 6, 2012 | 11:15 AM
For the EGR, start by cleaning out the EGR passages in the intake manifold. That's more common than an actual failed EGR valve.
ELD might be built into your under-hood fusebox. Depending on what year car you're talking about...
I don't know about the TCS error.
Old Feb 6, 2012 | 05:54 PM
g22cd5's Avatar
Supper Moderator
what year and trim accord?
rahulmunjal
Feb 27, 2012 12:10 PM
8lug
Feb 26, 2011 01:51 AM
con81a
Jul 1, 2009 09:52 AM
thebriz
May 17, 2009 11:42 AM
TRIGGA
Oct 11, 2006 10:02 PM
