Engine with internal sound attenuation barrier
Old Sep 16, 2009 | 03:16 AM
sahar's Avatar
Banned
Default Engine with internal sound attenuation barrier
An internal combustion engine of the type having so-called free standing cylinders or cylinder liners surrounded by an open topped coolant cavity is provided with internal sound attenuation barrier means, preferably mounted in the coolant cavity on the inner surfaces of the cylinder block walls or on the outer walls of the cylinders. The barrier means preferably comprises a rigid sheet engagable with the mounting wall and supporting a resilient sound absorbent material bonded or otherwise retained on one surface thereof. In a preferred embodiment the barrier material is a laminated steel having two spaced steel sheets bonded together by a rubber or rubber-like material encapsulated between the two sheets and formable into the desired shape of sound attentuating sleeve or barrier.
high speed internet service
lingerie bags
phantomgrey92
Oct 9, 2013 04:45 PM
tuti123
Jan 6, 2010 11:06 PM
vtecsk8r
Jan 24, 2008 07:11 PM
j_man_honda
Jul 22, 2007 11:26 PM
