INTERNAL ENGINE MODS FOR A TURBO
Old Jan 22, 2008 | 06:28 PM
vtecsk8r's Avatar
Default INTERNAL ENGINE MODS FOR A TURBO
wHICH IS BETTER TO TURBO A F22A OR A H22A. AND WHAT INTERNAL MODS DO I HAVE TO DO TO RUN HIGHER PSI LIKE AROUND 15 OR 20 PSI.
Old Jan 22, 2008 | 06:49 PM
BlkCurrantKord's Avatar
Default RE: INTERNAL ENGINE MODS FOR A TURBO
Mods..just lock this...
Old Jan 22, 2008 | 06:50 PM
sir_nasty's Avatar
F22 is better suited for boost since it's a SOHC and a tad less compression.... As for internals you'll want forged rods and pistons at the very least.... check out www.f22parts.com for a TON of stuff for the f22
H22A tends to be a much better N/A build
Old Jan 22, 2008 | 08:09 PM
j_man_honda's Avatar
15-20 psi??? Even with the upgraded internals the engine might last acouple dayson 15psi and a day on 20psi....
Old Jan 22, 2008 | 11:21 PM
falkore24's Avatar
It can be done for the right $$$$$. Full sleve job, head, camshaft, etc. Better off buying a crate race motor.
Old Jan 23, 2008 | 07:30 AM
As long as the bottom end is built and supported right and its tuned properly, the engine should last 100k miles if not more. Evena stockF23 has been shown to hold 17psi with no problems. Its all in the tuning.
If anyone can't find out what they need to know from this thread - you shouldn't be considering turbocharging your motor - http://www.honda-tech.com/zerothread...967&page=1
Old Jan 24, 2008 | 07:11 PM
KevinAccord's Avatar
good info Blk... thanxs
Blahhhh
11
Apr 2, 2012 11:53 AM
tuti123
Jan 6, 2010 11:06 PM
sahar
Sep 16, 2009 03:16 AM
j_man_honda
Jul 22, 2007 11:26 PM
