Engine Power Ratings - Fair?
Old Oct 3, 2006 | 03:13 PM
len1967
Default Engine Power Ratings - Fair?
I've noticed that engines are rated at revolutions that are all over the map.
Example.. .the DOHC H22A is rated at 161 ft/pd torque at 5500 RPM.
The SOHC F22B1 is rated at 147 ft/pd at 4500 RPM.
How can one really compare engines when they are rated at diff revolutions?
Does the DOHC really make a big difference, or does it just give more head room (so you can shift at higher RPM)...?
Old Oct 3, 2006 | 04:19 PM
Slusher's Avatar
Default RE: Engine Power Ratings - Fair?
Different engines are designed differently and therefore will generat power at different rpm. Typicaly, but not always, the dohc engines do make more power higher up in the rpm.
Old Oct 3, 2006 | 04:44 PM
len1967
Now that I am thinking about it, I vaguely remember seeing some torque curve diagrams comparing two identical displacement engines by the same maker.. one with SOHC and one with DOHC.
IIRC, the DOHC torque curve continued to increase for about 2000 RPM beyond the drop off point of the SOHC engine.. I'll have to see if I can locate some diagrams.. unless anyone has similar?
Model299
Apr 12, 2013 06:54 PM
hondaneeds
Mar 16, 2011 05:12 PM
andx0r
May 15, 2009 06:43 PM
hafajay
Jun 30, 2007 01:34 AM
VanIsle
May 10, 2007 04:58 PM
