Engine Revs by itself.
Old Mar 18, 2008 | 05:36 PM
Guest
Default Engine Revs by itself.
Well it's a 94 Accord EX with VTEC 2.2L. When I start it up after it's done warming up or while I drive it the Engine rev up and down between about 750-1500RPM. Egr Valve or Idle control valve?
Old Mar 18, 2008 | 06:13 PM
Default RE: Engine Revs by itself.
Idle control valve (IACV) on intake manifold.
Fast-idle valve (FITV) under throttle body.
Clean them out, & somewhere there's a thread about opening up the FITV & tightening something. (I haven't actually done this myself.)
Clean throttle body - any crud in the bore where the throttle closes?
Make sure the throttle cable & the throttle stop screw allow the throttle to close completely. Just in case some misguided mechanic has used them to adjust your idle speed.
Find & fix any vacuum leaks.
Search (probably in the DIY section?) for 'base idle'. There's a specific procedure. Don't just muck around with the adjustments, because the ECU will fight back & that's what causes the surging idle.
LonelyDora
Jun 26, 2013 06:02 PM
Spike817
Sep 9, 2010 06:22 PM
kubafle
Aug 17, 2010 06:51 AM
cenkaetaya
Feb 13, 2007 03:54 PM
zzzz
Jun 30, 2006 08:51 PM
