engine swap '90 accord
Old May 27, 2007 | 02:35 AM
Supin90AccordEX
Default engine swap '90 accord
okay.
I would like to put a h22 in my 90 accord. It has an automatic tranny. I want to be a 5 speed when all is said and over with. What all do i need to be able to pull this off and were do I buy it for the best price?
Old May 27, 2007 | 09:03 PM
Shadow1992's Avatar
Default RE: engine swap '90 accord
You will need to install a clutch hydraulic system (master and slave cylinders, pedal), gear shift lever and route the two shift cables, and proper transmission mounts.
If you go to www.cb7tuner.com you will find a huge amount of info on the 90-93 accords and your swap in particular, including instructions
D-Rod33
Nov 2, 2011 07:38 AM
hondahead23
May 9, 2011 08:55 AM
mfskarphedin
Jun 6, 2010 09:33 PM
StatzFinest
Feb 10, 2008 11:32 AM
