Engine/ throttle
Old Mar 11, 2013 | 08:33 AM
Soxxerms's Avatar
Question Engine/ throttle
Guru's
My car is 99 with the 4cyl motor. But driving it has issues. The throttle usage is like it's gargles ? Any gear. If I'm not flat on it it want to gargle on light push of the pedal or 50% push.
Wondering if this is fix I can do or it's going to require the shop to repair and the ball park cost you feel it should be also. ??
Old Mar 11, 2013 | 11:31 AM
You need to provide a better description.
Is engine hard to start? Hesitates when you try to accelerate? Misses, rough running?
Is Check Engine Light on? If yes, go to Autozone, et al and get codes.
Old Mar 11, 2013 | 05:31 PM
Soxxerms's Avatar
Engine starts is fine. Lil hesitates but gargles as you give it has unless you punch it. No missing runs good. Great gas mileage. No check engine light. But might have a lifter or value needing adjusting. Forgot about getting the codes so ill try that also.
Old Mar 12, 2013 | 12:45 AM
go-part's Avatar
Former Sponsor
Old Mar 12, 2013 | 11:40 AM
TPS is a possibility.
Your description indicates further diagnosis is necessary to isolate problem.
Try the TPS diagnostics and see if there's a problem there.
Also suggest disabling the EGR valve by removing the vacuum actuation line to the EGR valve and plugging temporrily. If this eliminates problem, then blockage of EGR passages in intake manifold may be the problem.
Old Mar 12, 2013 | 01:22 PM
Soxxerms's Avatar
Originally Posted by go-part
Thank you so much
Old Mar 12, 2013 | 01:25 PM
Soxxerms's Avatar
Thank you ill try them both
Chris_Strick
Aug 8, 2013 12:03 PM
Al_S
Jun 26, 2010 08:17 PM
TedsF23accord
May 7, 2007 05:07 AM
TedsF23accord
May 30, 2006 01:30 AM
nwurts
Jun 27, 2005 03:03 PM
