individual throttle bodies
Old May 24, 2006 | 10:31 PM
TedsF23accord's Avatar
Default individual throttle bodies
has anyone ever heard of or ever seen ITB's on an F23?
Old May 25, 2006 | 12:16 AM
marbro's Avatar
Default RE: individual throttle bodies
are you refering to a brand? or just a seperate TB in general? I got a 65mm TB but it didnt have cruise control on it, but im using it anyways, probably end up making something to attach the cruise cable to. But it was a TB intended for a integra gsr i believe, it had a different oring on the map sensor (f23 map oring is smaller then on the integra, but you can use the TB from an f22, h22, or h23
Old May 7, 2007 | 05:07 AM
Nightbreeze's Avatar
Hey man,
I know that I'm new to this forum, but I'm pretty sure that ITBs on an F23 will not work very well simply because there is not a whole lot of air in the back compartment of the engine. I have seen some ITB applications on K20 engines, but that is because the intake and exhaust are backwards on that engine, I mean like the intake is right in the front of the engine as opposed to the rear of the engine compartment with the F23. I had been thinking about modifying my engine with ITBs, but I figured that with inadequet airflow, that it would be a waste of time and money. The only way I think it would be feasible is if you had a hood scoop that directed air right into the ITBs. Anyway, this is why I think that you don't see ITBs on the F23 engine lol, but I could be wrong. Hope this helps...
Billium
Jul 19, 2014 03:03 PM
Al_S
Jun 26, 2010 08:17 PM
Plumcrazebody
Jun 20, 2010 07:33 AM
Devilmaykill
Apr 9, 2008 08:25 AM
nwurts
Jun 27, 2005 03:03 PM
