erratic idle when cold
Old Feb 24, 2014 | 05:35 PM
squeek's Avatar
Default erratic idle when cold
96 4 cyl 5 speed non vtec. It idles up and Doin when first start it up, but after a little driving its fine. Was told it probably isn't the IAC. Its had a new head gasket and was suggested that it wasnt torque right which is causing a vacumn leak. Any ideas?
Old Feb 24, 2014 | 08:56 PM
Head gasket torqueing doesn't cause vacuum leaks. Forget to re-connect a vacuum hose? Got any hoses that are hardened or cracked? Re-used any marginal gaskets at the throttle body or intake manifold?
Next you can check out the FITV - underneath the throttle body, it sets the fast-idle when the engine is cold. Maybe dirty, but also search for a thread about tightening a plunger inside that valve.
Old Feb 26, 2014 | 11:41 AM
squeek's Avatar
Well I got the car it was already done (I can see the new gasket)
Old Feb 26, 2014 | 03:25 PM
So you didn't replace the head gasket yourself. I guess the same questions apply; are there any vacuum leaks anywhere? And consider cleaning/tightening the FITV.
A headgasket that is not properly torqued can cause problems, but not exactly a vacuum leak. You might see coolant leaking, or maybe coolant getting into the oil, etc.
Old Feb 27, 2014 | 12:03 PM
gt massive2000's Avatar
I had that problem with a 97 accord idle up and down the fast idle under throttle body the plastic plunger back out I guess from vibrations after re tightening it was ok try looking into that head gasket won't cause that
Old Mar 6, 2014 | 11:58 AM
squeek's Avatar
Bouncing Idle Problem (IACV or FITV?) - Honda-Tech
Yup checked here as well, just an little more detail. Got it fixed. Cleaned tat throttle body out and it had some holes plugged up on ot
zedjr
Nov 1, 2012 05:03 AM
cryptonate
Nov 12, 2009 05:09 AM
Tai_Boi
Mar 29, 2008 01:08 AM
Planefreak
Oct 28, 2007 11:09 PM
mastar91169
May 11, 2007 10:36 AM
