F20B or H22??
my bad ..... I was thinking K
F series = cast iron sleeves ..... can be bored
H series = FRM sleeves ...... can't be bored
cast iron takes boost better. H cylinder head flows air better for NA ....... best is an F series with an H22A head.
ok i got ya!! now if i was to swap out the head where would i actually find one and wat F series will it fit on?? my engine still works fine but its goin on 170k and im not lookin to put aot in this engine u know
[/align]
I'm not the person to help you with the frankenstein engine build..... I'm not sure if the F's and H's have different models for pairing parts since I haven't really read up on it. As far as I know, the F's and H's all fit each other, but I'm likely wrong on that assumption. Are you looking to rebuild the lower half or is your compression good as is?
im trying to do everything!!! i just thought it would be easier to go with another engine, work on it slowly and then drop it in when im done with everything i want u know!! thats why i been do some research on the F series and the one that cought my eye was the F22B DOHC!
[/align]
well if you plan to do the whole engine, I think that an F series block is a better start than the H series due to the sleeves ..... if you're going to resleeve the engine, then it really doesn't matter, but if you want to bore the cylinder a bit to tighten up the compression, then F series FTW.
so your future plan is just to build the engine and leave it N/A, or are you gonna boost? it plays a role in the type of engine you should get. if your planning on boosting get the F, if your just looking for pure torque get the H and rebuild.
yeah im lookin to boost so i guess im rollin with the F then!! Thanks everyone for the help i appriciate it!! i don know everything yet about the Hondas, its really my second car but im lookin to really fix it up and learn at the same time!
[/align]
