F22
Old Mar 14, 2010 | 11:20 PM
92AccordEX's Avatar
Default F22
i have a 92 EX. i was just thinking performance wise, could i just swap my cylinder head from a SOHC nto a DOHC from a prelude of the same year? f22 block, F20B F20C or F22B head?
Old Mar 15, 2010 | 10:43 AM
F-series are SOHC (with only a couple unusual exceptions).
F20C & F22C (S-2000 engines) are COMPLETELY incompatible.
Prelude DOHC engines are H-series.
Search "Frankenstein" or "G-series" for H-series head on a F-series block. It's a lot of work & you might be better off just getting an H-series engine from a Prelude.
Old Mar 15, 2010 | 04:39 PM
You can put a H22 head on, but its far harder than just putting it on. There is machining that needs to be done and a lot of parts bought. Probably wouldn't be that much cheaper than just putting in a whole H22.
Old Mar 15, 2010 | 10:58 PM
92AccordEX's Avatar
ok thanks for the advice. but for performance what all counld i possibly do to this engince since ive been told that b d and h series engines are better then my f.
Old Mar 16, 2010 | 07:26 AM
What's "BETTER"??
B-series are small-displacement high-revving engine. Low torque. I had a fun GSR with B18C1 VTEC engine. 8,000 rpm and it was fun to use every last one. I think it would be a dog with a car as heavy as an Accord.
D-series? Seriously? That's like the small-displacement SOHC version of the B-engine. Comes in Civics before about 2005. You want to upgrade from 140hp to 120??
H-series. Yes. Better because of DOHC & higher revving. Same block architecture as your F, but like Rice says there ARE differences.
Old Mar 16, 2010 | 08:17 AM
Bisimoto makes cams for your engine. Bisimoto has also built F22s that make over 300hp all motor.
F22 is also a pretty good engine to turbo, its stock low compression and steel cylinder walls make it a pretty good candidate. You could easily make 200+whp and 250+wtq just by putting a turbo on and running 8-10psi of boost on a stock block.
Old Mar 25, 2010 | 09:18 PM
92AccordEX's Avatar
ok but to turbo wouldnt i bassically have to replace the pistons,rings,injectors,etc.? or could i leave all that in there. and if i can just leave it there what size could i get?
right now i have to get a cat-bak because my pipe is kinda split from the cat to the middle of the resonator if im not mistaken. found 1 on amazon for 169+ ship
Old Mar 25, 2010 | 09:45 PM
poser_pilot6
I recommend you buy a good cat-back. If you cheap out on an exhaust, you usually get what you pay for. Spend a few hundred. It's worth it.
Old Mar 26, 2010 | 12:02 AM
92AccordEX's Avatar
yea i seen a N1 on the net for about 205
Old Mar 26, 2010 | 08:43 AM
You dont have to replace pistons and such to run a turbo. Just dont run more than 7 or 8 psi. F22s have very low compression stock and steel sleeves so it makes them a pretty good turbo candidate.
