f22b1 or f22 etc.. head swap on a f22b2
Old Oct 7, 2008 | 08:38 AM
mist3rm0
Default f22b1 or f22 etc.. head swap on a f22b2
i have a f22b2 dohc non-vtec and i want ton know ifthe vtec head of the same enginebut vtec itthink is the f22b1 or a head of h22 ..etc will fit on my f22b2???anywayi want to swap a vtec head on my engine wish will work???
Old Oct 7, 2008 | 09:13 AM
Default RE: f22b1 or f22 etc.. head swap on a f22b2
f22b1 will swap on no problem, but its not worth it, the hp increase is minimal. h22 will work with some work/machining
Old Oct 7, 2008 | 09:46 AM
finch13's Avatar
And for the record the B2 head is not DOHC. Both B1 and B2 heads are SOHC and the H22 is DOHC.
Old Oct 7, 2008 | 05:27 PM
mist3rm0
h22 will work with some machining (oil way..?)..good..many years?? and what i need ...ecu..!? etc..
Old Oct 7, 2008 | 05:31 PM
I have not looked into it fully, But I believe the Deck has to be machined down a few thousands, I'm guessing the oil passages dont line up. And the fun part is the timing belt because the f22 block is sohc so it has a much shorter one that wont work. search g23 on google, thats what people call it when they do a f/h series frankenstein
littledrakon
Apr 30, 2013 02:55 AM
mikeym3693
Dec 8, 2012 11:53 PM
Joel Perez
Oct 24, 2012 04:40 PM
ebarrera661
Mar 26, 2012 04:42 AM
AbaZ
18
Jul 16, 2008 10:23 PM
