F22B2 to F22B6?
Old Feb 3, 2012 | 08:17 PM
Cody_754's Avatar
Almost A Senior Member
Default F22B2 to F22B6?
I'm getting an F22B6 put in my 97 Accord SE. The motor that's in my car is an F22B2. Is this a pretty clean swap considering they are both 4cylinder and 2.2liters? I'm only getting this swap due to an engine failure. I'm only trying to get a clean swap with no worries.
Old Feb 4, 2012 | 12:08 PM
Russianred's Avatar
Arrow
Any swap is clean if you make it that way.. What exactly do you mean CLEAN? Do you mean EASY? Or plug-and-play? What.
Old Feb 4, 2012 | 04:20 PM
Cody_754's Avatar
By clean I mean easy because I don't want to have to swap my ECU or engine harness or anything like that.
Old Feb 5, 2012 | 02:05 PM
Russianred's Avatar
Arrow
Should be 'clean', same engine basically, you should have no issues.
Old Feb 6, 2012 | 05:42 PM
g22cd5's Avatar
Supper Moderator
Tf22b6 engine other than it came from the Odyssey and creates 10 more hp than the f22b2 engine
They seem identical but tuned differently. The accord uses a 4-1 cast header with P0A P0B ecu. The f22b6 uses the 4-2-1 header with P14 ecu for 1995 and P1E ecu for the 1996 and 1997 models. So the ECU swap is a MUST.
Old Feb 6, 2012 | 09:56 PM
Cody_754's Avatar
Is it bad if the engine is just swapped and not the ECU? Because I have a shop doing it for me and I'm supposed to pick my car up tomorrow :/
Old Feb 6, 2012 | 10:17 PM
g22cd5's Avatar
Supper Moderator
I'm sure it will run but might not run all that great. As the cam shafts are little bit different
F22B2 - Intake Lobe Height - 38.526mm
F22B2 - Exhaust Lobe Height - 38.778mm
F22B6 - Intake Lobe Height - 38.741mm
F22B6 - Exhaust Lobe Height - 38.972mm
It also uses a different exhaust manifold. As I stated before. So the tune is not going to be 100% perfect like your old engine was. I would bring this info to the mechanics attention and see if you can't find a P1E ecu. Most ppl don’t understand the importance of have the correct tune.
Old Feb 6, 2012 | 10:50 PM
Cody_754's Avatar
Well I want it to run good so couldn't I get an ecu pulled from a wrecked 95-97 Honda Odyssey? Seems that would be the cheapest way out of it since an ecu chip is pretty expensive.
Old Feb 6, 2012 | 11:51 PM
g22cd5's Avatar
Supper Moderator
yes that's what I suggested to do in my last post....
You need a P1E ecu that came out of the 96-97 Odyssey
Old Feb 8, 2012 | 10:45 PM
Cody_754's Avatar
Ok I got my car back and the engine runs really smooth. My only problem is that the engine won't go past 3000 rpms...very annoying. Is that because I didn't get the ecu swap? I didn't think something like that would cause my engine not to go past 3000 rpms. It acts like it has a governor on it even in neutral. It feels like it bogs down. Please help me fix this!
