F22B2 Wants N/A Bisimoto
Old Jul 9, 2009 | 01:06 AM
Texas4Banger09's Avatar
Default F22B2 Wants N/A Bisimoto
Anyone familiar with Bisimoto? I want to make my F22B2 N/A. Not really lookin into a huge boost but I wanna be able to run with the stock Mustangs of the world so 250hp? Where is a good place to start as far as internals? I don't have VTEC should I start with that? Their headers are mighty pricey but I'm guessing they are the best out there for my specific engine. Is a camgear goin to make a difference in hp? I figure that cams/valvetrains will, I know an ITB would as well, but besides that is there any boost I can gain from that, or maybe purchasing pistons from them?
Thanks
T4B
________
How To Roll A Blunt
Old Jul 10, 2009 | 12:45 PM
clutch811's Avatar
If you want N/A power youre talkin some big $$$. for an f22b2 youre gonna want to overhaul the internals and externals. N/A power is difficult and not cheap on 4 cylinders. you would need high compression pistons, rods, sleeves, cam, gear, valves, springs, port/polish, good header, ported or advanced intake, etc. plus fuel delivery and a very good tune. I probably missed some things lol
to beat mustangs personally i dont think youre gonna need 250 Hp. personally i would recommend an engine swap to the H22a, 200 hp and a lot easier, you get VTEC this way too.
Old Jul 12, 2009 | 01:38 AM
thanks a lot
________
UrLittleAngel live
Old Jul 14, 2009 | 10:02 AM
Jmoney's Avatar
this is false, I currently have a 91 honda accord f22a1 bisimoto level 2 cam pro valve springs intake full exhaust port and polished head non vtec and i walk your average mustang gt all day they are dogs
Old Jul 14, 2009 | 11:57 AM
clutch811's Avatar
youre very welcome texas
no its not false, you should reread. I was describing what it would take to make high N/A power out of the motors. mustangs are easy to beat, an f22a1 with a built head is some strong stuff. sure you can have all that work done, what did it cost you? I was just saying that its more value to just swap in an H22. they have lots more potential.
Old Jul 26, 2009 | 07:35 PM
If I wanna drop maybe $300... obviously not expecting a big gain... what should I get? I already have intake and exhaust... The stock headers look pretty big... anything I should look at? Will a VTEC head give me more throttle response or allow for the transmission to shift faster? Because my car is currently non-VTEC.
________
Glass Bubblers
Old Jul 26, 2009 | 08:07 PM
jasonfridlund's Avatar
vtec is not intended to work at the low end of the rpm band. vtec works by changing the amount the heads open and other timing things under heavy load (meaning above a certain rpm). hondas in fact are infMOUS for lack of low-end power, but they certainly make up for it in the high end. The only way to bump up urlow-end power seems to be a small turbo on a really low boost of maybe 5-6psi, ans this will (in theory) produce much better throttle response on acceleration as well as add some extra hp all throughout. Unfortunately, a kit as i mentioned with a good build can cost upwards of 3-4k.
Old Jul 26, 2009 | 10:28 PM
So should I get a cam gear? Or get my cam regrinded? note its SOHC
________
SexualExtacy
Old Jul 27, 2009 | 03:26 AM
any sort of aftermarket "regrinding" is just going to create fracture spots. It is best iif you get a new part. so yes a new cam gear would alter the rate at which the cams open and close etc. which is wat vtec is. by altering the cam gear ration you are essentially(although not exactly) creating a dohc type engine, the most powerful type made by honda.
Jap.Doe
Sep 8, 2011 06:21 PM
g22cd5
Jan 24, 2011 08:31 AM
bisimoto909
Sep 17, 2009 07:54 PM
live2rice
Dec 14, 2008 07:21 PM
