f23a1 internals
Old Aug 10, 2011 | 09:29 PM
kevo2.3L's Avatar
Default f23a1 internals
So I'm not going to lie I'm lazy and dnt have time to look up parts but just asking what internals do I need to build my engine for turbo I'm looking to get massive power out of it so I need to make sure nothing falls apart so if you could help it would be much appreciated its for a f23a1
Old Aug 11, 2011 | 08:04 AM
g22cd5's Avatar
Supper Moderator
I'm gonna be honest if your too lazy to search I'm gonna be lazy to answer. Come on dude for real? help yourself out and just search. You can't expect us to help you if you won't even help yourself out.
Sorry to come off as a A HOLE but you need to research...we aren’t gonna do all the leg work for ya.
Now if you do some searching and have some questions about things I will be more than happy to help you out. But you have to do some of the work too.
Old Aug 12, 2011 | 05:55 AM
kevo2.3L's Avatar
I dnt need you guys to build my set up I just need to know the basics cams pistons rods pulleys cam gear stuff along those lines.....
Old Aug 12, 2011 | 07:16 AM
g22cd5's Avatar
Supper Moderator
bisi cams/rods and pistons
say away from pulleys unless you like replacing your main bearings all the time.
Old Aug 12, 2011 | 05:01 PM
Tek310's Avatar
are honda's crankshafts not balanced from the factory? i mean not to precision specs but should be balanced right?
Old Aug 12, 2011 | 09:55 PM
g22cd5's Avatar
Supper Moderator
They would have to be balanced. If not you would not have the same compression ratios across the board
Old Aug 12, 2011 | 10:18 PM
Tek310's Avatar
i think we are talking about different things.
balanced as in noise, vibration, and harshness NVH.
being unbalanced as in having a wobble and destroying main and cap bearings.
if a crankshaft is so unbalanced it is throwing off compression, that engine is toast.
Old Aug 13, 2011 | 08:50 AM
g22cd5's Avatar
Supper Moderator
No we are talking about the same thing. If the c/r is way off then yes its toast. But your c/r can be off by 1 or 2 points here and there. Also will cause the vibration and eating up your bearings.
Old Aug 14, 2011 | 03:58 PM
kevo2.3L's Avatar
Yo did you guys go to school for this stuff or is it knowledge from over the years
Old Aug 14, 2011 | 05:55 PM
g22cd5's Avatar
Supper Moderator
trial and error. I'v been building hondas since be4 I could drive them. An I'm 24 now
