fuel tank pressure sensor
Old Apr 4, 2008 | 05:36 PM
djfunkyfritz's Avatar
Default fuel tank pressure sensor
ok so what is the differance between a fuel tank pressure sensor and a fuel pressure regulator.. i know that the regulator regulates the amount fuel being sent to the motor but what is the sensor for... and does any one know where the sensor is located on a 99 accord and how hard will it be to replace it
Old Apr 4, 2008 | 06:16 PM
sir_nasty's Avatar
Default RE: fuel tank pressure sensor
My first question is going to be what code you got that said the sensor was bad or why you think that's the issue? Are you sure it wasn't just a loose gas cap that threw the code?
Old Apr 4, 2008 | 07:45 PM
i pulled a P1457 i already had the car checked out and every thing passed and the only two options that remain are.. the sensor ismalfunctioning or the PCM ismalfuctioning..so i just want to see where the sensor is located and how hard it would be to replace it.. i know they run about 100 bucks so if i can replace it myself theres no labor charge.
Old Apr 4, 2008 | 08:57 PM
It's on the top of the gas tank. The Helm book says you gotta drop the tank to get at that sensor.
Nasty, I've been in his other thread where the rest of the story is laid out...
Old Apr 5, 2008 | 09:45 AM
Chiovnidca's Avatar
ORIGINAL: djfunkyfritz
The fuel pressure regulator controlls fuel pressure to the engine. It does this to more precisely control the metering of fuel.
The fuel tank pressure sensor monitors tank vapor pressure. The ecu uses it's input to determine if there is a vapor leak in the tank or canister systems.
It's on the evap canister just in front of the gas tank.
Old Apr 5, 2008 | 11:14 PM
ORIGINAL: Chiovnidca
OOPS... You're right, its on the canister not on the tank. I don't know what I was thinking about.
Old Apr 7, 2008 | 05:41 PM
alright.. well besides the dealer... does any one know where i can find the sensor? ive been looking but no luck yet... if not ill call the dealer.
Old Apr 7, 2008 | 05:49 PM
never mind.. i found them at autozone... i swear it was not there the other day... ok so is it pretty easy to locate the canister?sensor... is it a pretty easy replacment or is there a lot to it
Old Apr 7, 2008 | 11:20 PM
When mine threw P1457, it was a valve that I could remove. I didn't have to remove the canister out of the car. That looks like it would be a chore, with not really a lot of room to get your tools or fingers in to work.
Old Apr 7, 2008 | 11:25 PM
The sensor is #36. It's positioned just forward of the canister, above the 2-way valve (which is #14).
