full H22A conversion question
Old Nov 13, 2012 | 06:42 PM
joey30gonzalez's Avatar
Default full H22A conversion question
I'm going to need to replace the motor in my 94 accord soon and I want to put in a H22A. I currently have a F22B1 with an OBD1 computer. I am planing on buying the full conversion from hmotorsonline.
Here is the link to what i was planning on buying:
http://hmotorsonline.com/shop/sc2000...age&item=30017
As you can see it comes with;
- Motor
- Hydraulic Tranny
- ECU (P13)
- Axles with Half Shaft
- Shifter Cables
- Shifter Assembly
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
My question is, since it coming with the proper ECU and engine harness will I still have to do any splicing of wires?? What will I have to splice exactly? I've tried googling the hell out of this but I haven't found anyone asking what to do if they are buying the motor with the engine harness and the ECU that came with the motor.
Also will i have to do a cable to hydraulic clutch conversion??
Old Nov 17, 2012 | 05:36 AM
holmesnmanny's Avatar
I'm guessing the harness only goes to the shock tower plugs. If so, you will need to add iab's and knock sensor wiring. rywire.com sells a kit. You should already have the vtec pressure switch and vtec solenoid assuming you do have the f22b1 motor as you say. I'm hoping the harness is plug and play, I used my original harness for my swap.
Also, you will need to swap pins A6 and A11 at your ecu connectors when you plug in the h22a ecu. I hope you're not in CA as that ecu won't pass smog here. You will need an h22a1 ecu.
92accordwagon
Nov 22, 2009 10:22 AM
BlkCurrantKord
Apr 27, 2008 09:27 PM
abit2theright
Feb 14, 2008 09:57 PM
hitek85
Feb 12, 2008 10:32 AM
boots
Jan 9, 2006 04:14 PM
