G23 info
Old Oct 31, 2007 | 11:30 AM
00AccordLX5spd's Avatar
Registered User
Default G23 info
Anyone with questions about the infamous G23 "frankenstein" engine, click here: http://www.honda-tech.com/zerothread...336&page=1
Old Oct 31, 2007 | 03:34 PM
marbro's Avatar
Default RE: G23 info
and keep in mind that it changed, it went from a h23 head to a f22b dohc head which is much rarer, and the dyno is based on a prelude that i believe was gutted to weigh 2400lb's
Old Oct 31, 2007 | 03:38 PM
falkore24's Avatar
ORIGINAL: marbro
... the dyno is based on a prelude that i believe was gutted to weigh 2400lb's
huh??? weight doesn't factor into the dyno. Definately acceleration, braking, and handling, but not the dyno #'s
Registered User
Yeah I knew the dyno was based on a lude, but lots of build info is there. One of the mods on 6thgenaccord.com has a G23 in his 6th gen. He dynoed it at around 155whp.
Old Oct 31, 2007 | 03:41 PM
falkore24's Avatar
daNG ..... pretty crappy peak HP ....... that doesn't tell the tale of the curve though!!!
Old Oct 31, 2007 | 06:38 PM
marbro's Avatar
still involves a crap load of dyno work and redoing the fuel map.... i would assume that they werent running a 6th ecu either? and im sure they didnt increase the compression or bore out the sleeves
Old Dec 4, 2007 | 01:13 PM
KevinAccord's Avatar
that doesn't sound like such a good idea now... just 5 more HP? wtf?
Old Dec 4, 2007 | 01:21 PM
falkore24's Avatar
Kevin ...... did you know that you can't really tell anything about an engine's performance by it's peak HP? HP is calculated, torque is real. What matters is how much torque you are making per rpm before the peak. The peak matters when you are on the track, but that's about it. The torque delivered by this build from 2000-5000 rpm's is what makes it a very good idea. This is what you use for a daily driver!
HP = (rpm*ft.lbs.)/5252
Old Dec 4, 2007 | 01:29 PM
WOW! thank you! i didn't knew that actually... Falkore, ur the man! i knew torque was inportant as well as HP, but not that it was that important! so u think it's a good idea for me to get the H22 head? or is it the H23?
Old Dec 4, 2007 | 01:37 PM
Registered User
ORIGINAL: KevinAccord
That's wheel horsepower. The stock 6th genf23a1accord has 150 at the crank, not the wheels. A stock auto accord probably only puts like 120hp(that's being generous)to the wheels. A little more for the manual transmission, but still nowhere near 150 to the wheels.
