Gas mileage drop with no check engine light
Old Feb 29, 2020 | 04:19 PM
rider56AK907's Avatar
Originally Posted by JimBlake
After a good drive, walk around the car & see if any of the wheels are noticeable hotter than the others. But realize the fronts will be hotter because they do more braking work, and because of the engine heat. This is a better test if you already have a good idea of how hot they get "normally".
Another easy way to check is in a flat smooth parking lot. Get going slowly, about walking speed. Shift to neutral & coast, paying attention especially when it comes to a stop. Dragging brakes will make it lurch a bit right as it stops.
But the best way to check for dragging brakes is to lift each corner & spin the wheel.
There's other things that are less likely, so if neither the O2 sensor or the brakes are the culprit, come back for other things to check. It's a process of checking & ruling out each idea.
- tire pressure - you already checked.
- oil change - done; but does the engine use any oil between oil changes?
- engine developing more blowby, indicated by oil blowing back thru the vent into the air intake duct?
- clogged catalytic converter? (but I imagine you'd notice a loss of power)
I've often seen a dirty air filter as a suggestion but don't understand that. Unless it's an old carburated engine, a dirty air filter is equivalent to not opening the throttle as much. Probably good for MPG while limiting the max power.
this problem started right after I got my snow tires put on so I called the tire shop that did the changeover and asked them if they could’ve bumped one of the calipers by accident and they told me they didn’t and that I’d feel a definite change if brake drag was happening (which I didn’t). I’ll try that letting it coast in neutral idea you told me though and see if anything happens. But otherwise, I’m just gonna swap the upstream o2 sensor
Old Mar 1, 2020 | 07:28 PM
Let us know if you find something. This thread has my curiosity going and I like to know how it ends - regardless whether its one of my ideas or something else.
Old Mar 1, 2020 | 09:45 PM
I will keep you posted! just changed the upstream sensor and topped off my gas tank. I’ll let you know in 300 miles or so if anything changed
Old Mar 2, 2020 | 06:59 PM
and I got another question for you guys if you can answer this. My owners manual says the car takes 4.5 quarts of oil including the oil filter, and the past 3 times I’ve done oil changes it’s been taking 5+ quarts of oil to get it to the full level on the dipstick. I’ve parked it in my heated garage over night to let any oil settle to the bottom and I’m still getting low levels every time. Any clue?
Old Mar 3, 2020 | 09:27 AM
I don't have specs in front of me for the K-series engine, but a dry-fill is always quite a bit more than the oil-change quantity. I think that's based on allowing a kinda short time for the oil to drain. There's a couple things that could cause more oil to drain out - therefore more oil needed to fill. In my case, I rotate the tires while the oil is draining, and that allows more oil to drain as I lift each corner to swap the wheels around. Another one I can think of is some oil filters have a larger can which can hold a little more oil. If you drain the oil cold, then it would take even longer to drain completely.
To make a long story short, trust the dipstick level rather than the number of quarts. (I guess you could look for a part number on the dipstick to see if it belongs to the wrong engine, but that's kinda bizarre)
Old Mar 4, 2020 | 01:47 AM
so all oil filters that are for a certain car aren’t the same size? Weird. But yeah, I’m just going to trust the dipstick being it’s the stock one. Thanks for your help again. And I’ll keep you posted on my mileage results
Old Mar 4, 2020 | 11:39 AM
  #17
Filters have to be the same where they screw onto the engine. But sometimes the metal can is longer, or wider, or something. I'm referring to comparing the dealer filter against all the other brands you can find. It's usually not enough to account for 1/2 quart but all that stuff adds up.
zh122
Mar 20, 2018 07:17 PM
jacman747
Dec 6, 2013 07:29 AM
rob3201
Jan 22, 2009 05:09 PM
07AccordVP
Apr 11, 2007 03:49 PM
1995accord
Apr 29, 2006 04:32 PM
