H22 swap
Old Apr 14, 2008 | 12:45 PM
HondaPinoy's Avatar
Default H22 swap
would a H22 swap be a good idea for my 1999 V6 accord? i mean the car is heavy and im down grading in HP but i just want it to be 5 spd.
Old Apr 14, 2008 | 01:14 PM
BlkCurrantKord's Avatar
Default RE: H22 swap
No it wouldn't be a good idea.
Old Apr 14, 2008 | 01:37 PM
ORIGINAL: HondaPinoy
its not a down grade, they are rated the same in hp, and a h22 would romp on your v6.
however, its not worth it, because your car is a v6 so it makes the swap harder/more epensive, and its a 99 so have fun getting it to pass inspection
Old Apr 14, 2008 | 01:44 PM
HondaPinoy's Avatar
inspection? do you mean like it wont fit or something?
Old Apr 14, 2008 | 02:04 PM
it would take a whole lot more work than its worth to make it fit because the accord V6s engine bay is bigger than the 4cyl. and inspection i mean like state inspection(if your state has it)
nvm i see your state is florida and if i am correct they dont have inspection, so thats not a problem
Old Apr 14, 2008 | 06:04 PM
ta003
Also there is a legality issue with installing engine from an older model car into a new one. So any 98 or older h22 will be considered an illegal swap (emissions wise) on your 99. Again, this is only a problem if your state has emissions inspection.
I believe this info is correct, but others please correct me if I am wrong.
Old Apr 14, 2008 | 10:04 PM
HORSEPOWERJUNKIE2007's Avatar
HELL TO THE MOTHERF***ing NO!the V6 possesses more torque!and you do realize that to get a H22 with 5 speed AND then after installation is going to actually cost you around the same as to changing your V6 to 6 speed.....look plain and simple. either sell your V6(seeing how V6 hasa higher value then theI-4)and get an I-4 with manual or keep it auto or do the 6 speed manual because that right there is just plain nonsense. and yes it would be a downgrade, just because an engine PRODUCES 200Hp it doesn't necassarily mean that he'll be getting those to the wheels..
Old Apr 15, 2008 | 07:26 AM
falkore24's Avatar
HP is a ficticious number created for novices to be able to compare engine power from engines that do not perform the same.
HP = ft.lbs. of torque * RPM / 5252
Old Apr 15, 2008 | 09:21 AM
The engine bay of the v6 is not bigger than the 4cyl on the 6thgen accords. That only applies to the 5thgen accords.
Old Apr 15, 2008 | 01:51 PM
ORIGINAL: BlkCurrantKord
my b i only know 5th gens so assumed it would be the same
and they are both rated for 200hp and i know that obviously whp is diff than bhp, but i'm saying race that v6 vs a h22 accord and see what wins.
