H22 swap in 94 accord
Old Aug 8, 2015 | 06:03 PM
Jamesmecorney's Avatar
Default H22 swap in 94 accord
This is my first post, my name is Danny, I have a 94 coupe with an f22b1 (stock), want to swap for an h22 with the minimum amount of work. which code is best? I heard it was the a1 since I don't think there was an h22b1, but I may be wrong. Any help would be awesome
Old Aug 9, 2015 | 05:41 AM
Welcome to HAF.
The H swap is well documented - just be sure to take your time and plan everything before you start.
I personally would keep it stock and spend my time/money on the regular maint items - brakes, suspension, ect. The 5th gen with the F motor is a very well built car and will last a long time if you take care of the reg maint stuff.
Old Aug 9, 2015 | 06:51 AM
I would keep it stock, unfortunately this motor wasn't well taken care of and is pretty worn out, if I'm going to swap it I'd rather have the dual cam
Old Aug 9, 2015 | 06:52 AM
And thank you for the welcome
Old Aug 9, 2015 | 08:38 AM
Well if that is the case an the H is waht you are set on.....go for it
Again, the planning part of this should be the longest part of the whole thing....and I really do mean that.
Yes, something might come up during the swap that was not expected....that is where we come in
Old Aug 18, 2015 | 10:44 PM
Need to add another question...I'm in California, are there any obstacles to smog if I swap in an h22?
Old Aug 19, 2015 | 04:50 AM
Yes.
I don't live there and never had, so you'll need to do some research.
My high level understanding from talking with others. The engine has to be the same or newer than the one you are replacing. All emissions items have to be working - ok what is new. You will also have to get it "BAR'd" by a smog ref.
Again very high level, you need to search to get all of the details. Then add all of those to your planning process.
Go Honda GO
Jan 31, 2012 04:42 AM
tom6915
Apr 15, 2009 04:35 PM
juansosa57
Jul 2, 2007 08:59 AM
blksniper2000
Jun 28, 2007 09:35 PM
BuntinBoy9
Apr 5, 2007 06:07 PM
