H22 swap,improvement
Old Mar 10, 2008 | 02:53 PM
HORSEPOWERJUNKIE2007's Avatar
Default H22 swap,improvement
What do you guys think of this?
H22 engine
auto transmission
underdrive crank pulley
V2 intake system
dual exhaust
how many horses would this be?and what else can i add to get it kicking around 300 Horses...
P.S don't worry about money just give me your honest opinion..
blkcurrant and 97 accord i invite your comments.
Old Mar 10, 2008 | 02:59 PM
finch13's Avatar
Default RE: H22 swap,improvement
Dude, H22 are only rated from 190 - 220 HP stock, you'll be lucky to be pushing 200 - 240 HP after those mods. Turbo or spray from there to get it to 300 HP...
If I were you I'd drop the auto and get a manual; a lot of the power is going to get lost in the torque converter.Stay away from SH Prelude trannys too.
Old Mar 10, 2008 | 03:05 PM
to get 300hp you are either going to have to
A)drop in high compression pistons, aggressive cams etc etc etc
B)Turbo, which isnt a great idea on a stock h22
C)Nitrous which also isnt a good idea
and last but not least having 300hp going through a slushbox tranny is a complete waste of time and money
Old Mar 10, 2008 | 03:09 PM
DA KID RYU's Avatar
Yea from what i heard an h22 is nothing if its auto....
if you do turbo or spray and go that road u have to re-sleeve it..
h22 sleeves are weak from what i read they are made of a weak material frm..
sleeve it drop compression pistons roads the whole nine yards..
n yea h22 are pushing 190-220 if thats the jdm h22...
Old Mar 10, 2008 | 04:39 PM
BlkCurrantKord's Avatar
ORIGINAL: HORSEPOWERJUNKIE2007
H22 engine
auto transmission
V2 intake system
dual exhaust
Ok
Useless
Useless
Ok
Useless
Good luck trying tofind the ecu so you can run the auto trans with your OBD2 motor b/c thats pretty much the only way you'd ever be able to do that. Anything else is a wiring nightmare.
I think some of you fail to realize that the H22 is pushing that 190-220hp at the crank on different models, not the wheels. They usually put out about 160hp, 140lb/ft at the wheels.
Old Mar 10, 2008 | 10:05 PM
Ah thats no good then.forget it i'll just drop in a J30A1 or J32A2...thanks anyways...
Old Mar 11, 2008 | 06:52 AM
LOL - Good luck trying to do that too.
Old Mar 11, 2008 | 11:22 PM
LOL you know you are a very confusing character...what's my best bet?seriously because you making me think i should just stay stock or something...H22 don't sound good enough and the J series sounds complicated lol what's my best bet seriously???
Old Mar 11, 2008 | 11:24 PM
i won't even be greedy or unrealistic....is it possible to keep my stock engine and get it at leastkicking around230-250 Hp..if so how?...
Old Mar 11, 2008 | 11:34 PM
nrmskate's Avatar
Turbo and spray with would be your best bet when modding your stock engine.
Intercooler. ECU Manager. New Tranny. Little mods will just keep bringing you up small amounts of horsepower.
and If you have the time and money... I believe you can get to 230-250HP.
Juts believe in yourself.
