H22a VS H22a Type S
Old Feb 1, 2008 | 03:05 PM
hitek85's Avatar
Default H22a VS H22a Type S
Does anyone know the major differences between the h22 and h22 type 2.
From what I have read there is about a 20hp difference between the two.
Anyone know why? I have seen about $1000 difference between the two also...
Pistons? Cams? Intake manifold?
Old Feb 1, 2008 | 07:07 PM
BlkCurrantKord's Avatar
Default RE: H22a VS H22a Type S
H22-S has different cams, stock ported head from the factor, higher compression (11:1) Intake manifolds are the same across the board.
Non-typeS have 10.5/10.6:1 compression
Old Feb 1, 2008 | 09:25 PM
blkcurrantkord is correct, IMO its not worth the $1000 more, you can gain 20hp with mods that cost alot cheaper than $1000, and just get aftermarket cams cough skunk2 cough that will give you way better performance.
Old Feb 10, 2008 | 10:56 AM
Velocifero's Avatar
ORIGINAL: live2rice
USDM H22 has a 10.0:1 ratio, JDM has a 10.6:1 ratio. is it worth an extra G? pricewise no, but convenience yes. Type S cams and pistons are also one of the best for this motor. factor that into the factory port job and intake manifold, and it isnt too bad. I'd personally rather have a Euro R H22 myself with the single stage intake manifold though.
Old Feb 11, 2008 | 01:31 PM
accrd94ex's Avatar
with that 11:1 you would need almost 100 octane to be safe driving it with out pinging you got to think the japs gas is better and higher grade than ours is. Anything over 10.5:1 to one you are looking at at least 93 octane or higher preferably higher that compresssion is really high.
Old Feb 12, 2008 | 10:01 AM
91 or 93 is perfectly fine for 11:1-11.5:1 compression. More like anything over 12 would need race gas or a mixture of race gas and regular gas (93 octane)
Old Feb 12, 2008 | 10:32 AM
Velocifero's Avatar
ORIGINAL: accrd94ex
most likely, the manual says 93 octane for 11:1 too. i use 93 with my 10.6:1 and it runs great.
jdmjnky
Sep 21, 2010 11:21 AM
jq_quint
Oct 12, 2009 02:49 PM
9JordonAccord9
Jan 13, 2006 11:46 AM
wardykid23
Apr 17, 2005 11:58 PM
maxst2
Nov 23, 2004 12:02 AM
