HELP on my 91 Accord
Old May 7, 2009 | 11:12 PM
aguy63
Default HELP on my 91 Accord
My accord is throwing two codes, a tps code and a tdc code. I switched the tps but it still gives me the code. please help. It turns off when it comes back to an idle. Idles fine when its in park or neutral, but when u put it in reverse or drive it stalls when you come to a stop. Please help me out.
Old May 19, 2009 | 06:11 PM
draser's Avatar
Sounds like you looked up the codes, is there a troubleshooting guide in a manual for your model year? I know I have one for mine, but I have a 99.
You know the throttle position is good, and the other one - top dead center?? - that's a sensor on the crankshaft ... it looks like an wiring problem. Need a service manual for your year - try this forum - and locate the diagram for the tps and follow the wires down to the ECU, same for the tdc.
Was there any work done on the car lately, or in other words how's this come about?
Let us know - always like feedback.
Old May 20, 2009 | 08:14 AM
I'm pretty sure in 91 that all timing sensors are located in the distributor.
CKP = crankshaft position
CYP = cylinder position
TDC = top-dead-center
Those are not replacable by themselves, you have to buy a new distributor. But you CAN check for loose/dirty/corroded pins in the multi-wire connectors right there at the distributor.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
