How do I check TiminG
Old Aug 2, 2006 | 01:48 AM
hiTmanG11's Avatar
Default How do I check TiminG
This might be the wrong section but there seems to be more traffic here
Im guna need to check and or adjust my timing here soon on my 93LX
and of all the things ive done ive never done timing before
ive searched but couldnt find anything
if sumone could just give me a quick walk through id much appreciate it...
thanks guys
Old Aug 2, 2006 | 01:38 PM
lightshow's Avatar
Default RE: How do I check TiminG
you just need a timing light....shine it on the indicator and then turn the distributor left or rightto change it, but you should never have to time it unless you had to change out the distributor.
Old Aug 2, 2006 | 08:05 PM
Chiovnidca's Avatar
ORIGINAL: lightshow
Or if you put a timing belt on it.
The access hole to check the timing is between the engine and trans above the seriel number. You have to remove the rubber plug.
Old Aug 2, 2006 | 09:17 PM
hiTmanG11's Avatar
ORIGINAL: Chiovnidca
ORIGINAL: lightshow
So im aiming the gun inbetween the engine and the trans??? also how do i adjust it at the distributor?? what am i turning... do i take the black case off the distributor to do this? Sorry im alil lost on this one
Old Aug 2, 2006 | 09:29 PM
sir_nasty's Avatar
Not a problem it doesn't make sense unless you've done it before.... so here goes...
Find the split/line where the transmission meets the motor and follow along it towards the front of the car and you'll see a little rubber plug (it may have already fallen out or been removed...) remove that plug. Now hook up your timing light and shine it through that hole you'll see a little line (typically it's white or red) that shows up when the light flashes (be sure you're on the #1 plug wire with the gun which is usually the far left as you face the engine) now off to the right of that little light you'll see something like a point (resembles the head of an arrow) the line should be in line with that point for the most part (it jumps around a bit but for the most part it lines up) if you need to adjust it that's where the distributor comes into play.
Adjustment: under the distributor (the black cap that you spoke of) you'll see a little bolt that is either a 10 or 12 mm bolt that holds a plate on and connects to the distributor. Loosen that bolt and it will allow you to rotate that black cap. Rotate that black cap at VERY small incriments and you'll see the line move forward or backwards depending on which way you rotate it. Once it's in line tighten down the bolt, replace the rubber cap and you're done!
Old Aug 2, 2006 | 09:51 PM
hiTmanG11's Avatar
ORIGINAL: sir_nasty
thank you nasty
Old Nov 22, 2006 | 03:05 PM
accordfan222's Avatar
I am new with Honda accords. this is great forums where we learn a lot and thanks to every body who had give us great inputs. I have never done anything with the timing. My 97 accord SE might have same problem as this(set up the timing). I have timing belt and balancer belt changed by the local shop (when I bought this car used at 184000 miles, belt was never changed since previous owner had told me). I am feeling under power on the engine after the belt being replaced. Specially I am feeling low power at low speed(from 0 to 40 miles). Engine seems to have less power (compare to power before timing belt change) at low speed. At the higher speed around 60 to 70 mph car seems to work ok. I already have replaced the spark plug, wires and distribution cap (same time when replaced the belt). You think it is timing or the distribution cap itself. If it is timing problem, is this the same procedure to do as you described in this thread??? Really appreciated it for your help.
Old Nov 22, 2006 | 03:35 PM
sir_nasty's Avatar
to check your timing just go through the steps listed above and that will tell you if it's the culprit or not
Old Nov 23, 2006 | 02:11 AM
Chiovnidca's Avatar
ORIGINAL: sir_nasty
Looks like we forgot the part about jumping the service check connector.
Old Nov 23, 2006 | 09:00 PM
Where is this service check connector located and how one can jump it out !!!
ORIGINAL: sir_nasty
