How do I check TiminG
Old Nov 24, 2006 | 06:09 AM
Chiovnidca's Avatar
Default RE: How do I check TiminG
ORIGINAL: accordfan222
Where is this service check connector located and how one can jump it out !!!
97 accord? Under the glove box. a paper clip works good.
Old Nov 27, 2006 | 03:52 PM
ORIGINAL: sir_nasty
... (be sure you're on the #1 plug wire with the gun which is usually the far left as you face the engine)...
The #1 plug wire is always the one farthest away from the flywheel. Or closest to the alternator drive pulleys.
Old Nov 29, 2006 | 06:17 AM
itzztrick's Avatar
Is it the same instruction for 2001 LX?
Old Nov 29, 2006 | 11:03 AM
ORIGINAL: itzztrick
No. Your timing marks are on the front pulley, not on the flywyeel.
There should be a pointer molded into the lower timing cover, & notches in the outer rim of the pulley. One notch all by itself is TDC. To the left of that is a set of three, the big middle one is stock timing. The 2 little ones are +/- tolerance around stock.
But on 2001 I think the timing is not adjustable. You should find that the mounting holes for the distributor are not slotted.
john_pyro
Aug 4, 2019 05:06 PM
marti777
Jan 5, 2017 06:18 PM
RA1525
Apr 15, 2012 07:50 AM
noltian
May 29, 2011 11:56 AM
Tony1M
Apr 1, 2007 05:42 PM
