How do I check TiminG
ORIGINAL: sir_nasty
... (be sure you're on the #1 plug wire with the gun which is usually the far left as you face the engine)...
ORIGINAL: itzztrick
Is it the same instruction for 2001 LX?
There should be a pointer molded into the lower timing cover, & notches in the outer rim of the pulley. One notch all by itself is TDC. To the left of that is a set of three, the big middle one is stock timing. The 2 little ones are +/- tolerance around stock.
But on 2001 I think the timing is not adjustable. You should find that the mounting holes for the distributor are not slotted.
RA1525
Apr 15, 2012 07:50 AM
